Where can I find a distribution maps free except xerox map viewer?
I have the distribution maps free xerox map viewer, but I have a problem when I zoom at the maps. Is there another distribution maps free to download?
Hi Robert,
The use of Xerox Map Viewer has said to be discontinued a long time ago.
For alternatives, you can use DIVA-GIS for your future distribution map queries. DIVA-GIS is a free computer program that allows you to make maps and perform geographical data analysis using GIS.
You can check out there website for more details. Here is the link: http://www.diva-gis.org/
Robert,
It is difficult when the programs we use become outdated or quit being supported, it is nice, however, to have choices to compare with. I have found another, free choice (it is free for 60 days which will allow you time to test it out before you decide on whether or not you want to purchase it) for you to compare to. ArcGIS Publisher allows you to share your maps and other data with other people. This website will give a rundown of how the program works and what you need to do to get it installed. The website is: http://www.esri.com/software/arcgis/extensions/publisher.
