Scott Broek
20 points
Posted on - 04/22/2013
Hi. I use a 2.4 GHz D-Link N300 wireless USB adapter with WPA2 protection for sharing my internet connection wirelessly. My LG Optimus F7 that has a Dual-core 1.5 GHz CPU and Android OS Jelly Bean could not detect my D-Link adapter. Where can I find a driver android d link USB?
Where can I find driver android d link USB?
Hello
Here is the support page for the D-link modems. You can download any driver version for your device here.
You firmware on your device also might be outdated. If the drivers do not get the modem to work on your Android device then upgrade the firmware here.
Please make sure to check that you are updating to the latest firmware version.
Hello Scott,
You want to use a driver android d link USB which is compatible with your Android Smartphone (Jelly Bean). In this case you can try D-Link Share port mobile which is designed to give you access USB drives and WI-Fi services. This app supports both Android and iPhone. You can connect USB storage drive into D-link router and access files any device connected to your router. It can also provide services like:
1. Wireless Router
2. WI-Fi hotspot
3. Repeater
