Dallas Corey 50 points N/APosted on - 03/17/2013
Hi there. I have an HTC Desire with Qualcomm QSD8250 Snapdragon chipset, 1 GHz Scorpion CPU, HSDPA, 7.2 Mbps and Android Froyo. I would like my desktop to connect to the internet via my Desire's mobile network. Where can I find drivers USB internet desire?
The HTC Desire Android Froyo don’t need any USB driver for it to work or use if you are having a problem using the USB port of your PC, it’s not the Phone that you need to fix but the USB port. Try to install its driver then go to the Mode called USB tethering to have Internet.
When you connect your phone to your computer it should be recognized as a normal USB flash drive. It should show you the files which are stored on your phone. If that's not the case on your computer then something is wrong with your USB port. Go to device manager and check if all the drivers are installed. If not, then install them and try again. Regards.
The HTC Desire is a 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled to the public on February 2010 and released on March 2010 measuring 119 x 60 x 11.9 millimeters and weighing 135 grams. This phone has been discontinued.
HTC Desire
It uses mini-SIM card with Optical trackpad and has AMOLED or SLCD capacitive touchscreen display with 16M colors at 480 x 800 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass with HTC Sense UI. It runs on Android 2.1 Eclair upgradable to Android 2.2 Froyo powered by Qualcomm QSD8250 Snapdragon S1 chipset, 1.0 GHz Scorpion processor, and Adreno 200 GPU.
It supports microSD expandable up to 32 GB. It runs on 576 MB RAM with 512 MB internal storage. The primary camera supports 5 megapixels with LED flash and autofocus featuring geo-tagging. It supports 480p video recording at 15 fps and 720p at 30 fps after SW update. There is no secondary camera.
It has 3.5-millimeter jack, Wi-Fi 802.11 b/g with hotspot support after upgrading to Android 2.2, Bluetooth 2.1 with A2DP support, GPS with A-GPS support, stereo FM radio with RDS support, and microUSB 2.0. It has built-in accelerometer, proximity, and compass sensors. The pre-installed web browser supports HTML with Adobe Flash support. Java is supported via Java MIDP emulator.
It runs on removable Li-Ion 1400 mAh battery with standby time up to 340 hours on 2G and 360 hours on 3G. Talk time is up to 6 hours 40 minutes on 2G and 6 hours 30 minutes on 3G. It is available in black, brown, silver, and white colors.
Now, if you want to share your phone’s internet connection with your computer, you need to install the HTC Sync Manager. It will install the necessary drivers for your phone for tethering.
1....
