Where can I find endnote x2 for Mac
I know that the second version (x2) of endnote is now available, and its very effective for daily use. Where is the place to download endnote x2 for mac ?
It is true that the second version of Endnote is now available. It is a very useful software.
You can download it here – https://www.macupdate.com/app/mac/6436/endnote.
To install this software you need to have Mac OS X 10.5 or higher.
1. Go to the website above and click on "Download Now'.
2. Save the file on your hard disk. After the file is downloaded, install it on your computer.
3. Restart your computer after installing.
Hope this information helps you.
The version you are using, EndNote X2, is very old. The latest version is EndNote X7.4. To update to this version, you can do it in 2 ways: automatic update or manual update. Any of the 2 methods require that you already have EndNote X7 installed. If you don’t have it, visit EndNote X7 Free 30-day Trial and download a copy.
Once downloaded, install it on your computer. To do the automatic update on EndNote X7, follow these. Exit any programs that are currently running. Start EndNote then click on the EndNote X7 menu. Select “Check for Updates” then just follow the succeeding instructions. Once the update is finished, click on the EndNote X7 menu again and then go to “Check for Updates”.
This is to check if there are still available updates to install. If you want to install the update manually, here’s how to do it. First, check the current version of EndNote that you are using. To do this, start EndNote, click EndNote X7 menu, and then go to About EndNote. If it reads EndNote X7.4 then you have the latest version.
For EndNote X7.3.1 and earlier, download the EndNote X7.4 Cumulative Update. Quit EndNote if it is running. Go to the download folder, unpack the downloaded ZIP file, and then run the file. When the process is finished, start EndNote, click on the EndNote X7 menu then go to About EndNote. If it now reads EndNote X7.4, you now have the latest version.
Notifications
