Emaily Rawa
10 points
Posted on - 12/24/2012
I am looking to buy a Configurateur visual presta. I badly need it. I actually bought it once.
But it was in the unknown language format. I need an English version.Â
Can you please help me to find an English version of Configurateur visual presta?
Where can I find an English version of configuration visual presta?
Unfortunately there is no available English version of the configurateur visual presta. All of which are in French. However, you can download the module configurateur visual. It works by helping you with the language barriers. The module works very well. You can download it at http://demo.configurateurvisuel.fr/.
It installs quickly and is virus and spyware free.
Hey. Emaily Rawa,
I got your problem you need an English version of Configurateur visual presta. Well, unluckily there is no available English version of Configurateur visual presta but you are lucky that we are here to help you. I am stating simple procedure you have to follow steps in order to get the English version.
Download Google Chrome and open it then it asks you to change it to English. Just click yes. It will automatically convert it to English.
Click on more after visiting google.com
Now you can translate your document from any language to English.
I hope that this will work for you.
Thanks & Regards,
Gillam Janetj
