Where can I find free web directory submit link?
If not free at least very cheap web directory submit link websites? I am really working on a very tight budget. It will be a very big help if you could show me some sites.
Thank you in advance!
You can submit we directory links for free on some websites. You just need to select the topic and the category under which they fall and click submit. There are also a few websites that charge a nominal fee for this. As you are working on a tight budget I would suggest you to use the free web directory submission links. You have to be careful when you select the category and the topic under which your links come as you cannot change them later. The following are the websites where you can submit web directory links for free:
1. mmli.org – http://www.mmli.org/
2. Directory Critic – http://www.directorycritic.com/
3. So Much – https://somuch.com/.
