Where can I find free zip and mail?
Can anyone provide me further instructions on how to use these programs and information as to where I can find free zip and mail?
Hi, Nelson Carters
As you know, from google you can find a lot of forums but the chances of getting the right solution depends on where you post your problems. We have so many different forums to download best zip application.
So classifying and posting them on relevant forums is the best way to get your answer step by step.
I can suggest you some good forums, which are listed below
1. https://filehippo.com/download_winzip/ (its working use it)
2. https://filehippo.com/download_winrar/32/
Hello Nelson, You need a file compression software and a mail client. If i am right then here is the complete help for you. For a compression software, i would recommend 7- Zip which is an open source software and you will not have to pay a single penny to use it. The download link for 7- Zip is below: http://www.7-zip.org/ For an email client, I would recommend mozilla Thunderbird. Again its an opensource application and you will not have to pay a single penny to use it.The link to download Thunderbird is given below: https://www.mozilla.org/en-US/thunderbird/
