Does anyone know a decent piece of software that can enable me to excess a Garmin map? I have searched on the Garmin website. I have not found any software likes that. I have also tried some which I have got on the web.
Can anyone please help me to find a Garmin map viewer software that really works?
Where can I find a garmin map viewer software?
Hi there user,
You should also try GPS Map Edit and GPS Map Viewer which will allow you to view routes and waypoints which could act as bonus features for the below suggestion.
GPS Map Edit and GPS Map Viewer are the ideal software which (somehow) could be useful along with the installation of Garmin Base Camp 4.0.5 which was developed by Garmin Ltd. Several years ago. Here’s the link where you can download it.
http://www.softpedia.com/get/Others/Miscellaneous/Garmin-BaseCamp.shtml
Thank you for posting your query here at techyv.com
Best regards.
