Where can I find Google desktop video recorders?
Where can I find google desktop video recorders available for download? I need a plugin version which I can use to browse videos using Google desktop browser.
Dear user,
I have done some research on the internet and have found a Google desktop plugin for you, I will recommend you
Google Desktop Plugin – Google Video 1.0.1
You should have Desktop Search 4 or above to run this plugin. When you find an addition sign button on the Desktop Search, just click it and you can browse through a long list of video gadgets by typing on the search tab keyword "video" and then Google Video gadget will be listed. Then, you just have to press the "Add" button and your work will be done.
Hope this will help you.
Thank you.
