Where can i find how to use image mount in acronis?
Where can I find the tool to install or use, which helps me to know how to use image mount in acronis?
Hi Alisa! I have instructions here on how to mount images in Acronis, but it is not for installation. I still hope this will help you.
For Mounting an Image:
If you choose a backup containing incremental images, you might as well choose the one with the successive incremental image, also known as “backup versions” through the date/time created.
If your backup has a password, Acronis True Image Home 2011 will ask for your password.
To mount incremental images successfully, you must have all previous backup versions and the initial full backup. Otherwise, it will not be possible.
The image mounted will be in “Read-Only” mode as set by default. If you want to set it in “Read-Write” mode, just check the option in Wizard. When you Unmount a “Read-Write” image, there will be a new incremental backup created with changes made to the mounted image.
The program will then run Windows Explorer after the image is connected, showing its contents.
To Unmount an image:
Click “Unmount Image” on the “Tools and Utilities” screen.
Select the disk you want to unmount and click “OK.”
For sample images, clear instructions, and more information visit this site:
Hi Alisa,
I had here a website where you can visit, http://kb.xploretech.com/Default.aspx?id=10266. You will see here the Motion Computing Knowledge Base Article that describes about how to explore archives and mount images using the Acronis True Image recovery software. It has a step-by-step procedure so it can be easy for you to follow.
I hope it could help you.
