jonchinha
210 points
Posted on - 06/24/2011
Hi all,
We know about internet protocol.
When we need connection for internet, then IP is needed. We setup IP address on my PC for net connections .
We know IP address location in my PC, but we do not know how to find our IP address on our server.
That means the location of IP addresses in the server.
Advice needed.
Locating IP Address in a server
Try using this link to locate the location of the server you are looking for. http://www.81solutions.com/index.php
But it also depends on the connection type of the server.
If it is dynamic, the IP address changes every connection, try to check if the type of network for the server is static.
Also might I ask why would you want to know the location of the IP address of the server?
In some countries that would be considered an invasion of privacy.
An easier way to also do this is to I log in to the server and run the command ipconfig, this should reveal the IP address of the server, also while in dos command also input this as well nslookup xxx.xxx.xxx.xxx.
That should do the trick
