I have downloaded most of my movies songs and soft wares from a windows FTP server which is provided by my internet connection provider. Recently I have bought a iPad.
And I am unable to use the same server.
My internet connection provider is also unable to provide an FTP server for iPad.
Can you please help me to find an iPad FTP server?
Where can I find an iPad ftp Server?
Hello there,
Well there are so many ways to transfer files from your iPad to your PC by creating an FTP Server.
I would suggest you to download a WIFI FTP version 4.0 in your IPad as this is the one I've been using since 2 years and its really user friendly and the advanced features are really interesting.
You can check it out the description in the below given link and then download it free of cost-
https://itunes.apple.com/in/app/ftp-server/id346724641?mt=8
All the best.
There are many applications available in the market which will provide you FTP server. I would like to recommend the best software 'Ftp Server (a simple FTP Server).
You can download this app for only $0.99. You can download this software from:
https://itunes.apple.com/us/app/ftp-server-a-simple-ftp-server/id460918363?mt=8
I hope this will solve the problem.
