I'm trying to make an e-commerce website using Joomla 2.5. I would like it to have the simple Apple.com feel. Is there a Joomla apple template freeware that I could use? I'm on a Windows XP 64 bit system. Thanks.
Where can I find Joomla apple template?
Hi there Hanley Samson,
First of all, the system you're using has nothing to do with the template for your Joomla, so that shouldn't bother you. The only thing that matters is the version of Joomla CMS you are using.
For simple and clean eCommerce templates I would suggest you to visit http://www.rockettheme.com/ or Gavick.com. Both sites are offering some awesome, simple and clean free templates that could fit nicely into your clean Apple vision.
Best regards,
Drake Vivian
