Where can I find a legitimate command/resources for Linux recover syntax?
Where can I find a legitimate command/resources for Linux recover syntax? I need to get  information, resources, samples or  commands that can be used for  linux recover syntax.
Best Answer by Abbot Nimrod
Answered By 0 points N/A #162667
Linux is a command based operating system. For recovering Linux syntax command / resources, "computerhope.com" can be a good solution for you. In this website you will find all Linux commands as well as you will find UNIX smbclient command. If you visit this site I think you will defiantly find the correct commands for recovering Linux syntax.
Answered By 0 points N/A #162668
Hi there: Although linux is one OS but has many flavours. Therefore in order to get the right syntax, you will need to rigt source for your flavour of unix: here are a few for the major flaovours: http://www.debianadmin.com/basic-linux-commands-with-man-pages.html for debian; www.linuxquestions.org for Red Hat linux; www.centos.org for centos. You will find the required commands at these resources. Hope this helps.
