I have an iMac that has a 2.7 GHz Intel Core i5 processor, 8 GB RAM, 1 TB HDD, Nvidia GeForce GT 640M Graphics processor and an upgraded OSx from Leopard to Mountain Lion. My Lexmark printer now won't work with Lion. Where can I find the Lexmark pinnacle pro 900 driver update?
You may also read the technical documentation and system requirements from their website, as it is critical for your device to run on your Mac device. You may also want to update your system before you install the drivers, as this there are critical system instructions which the installer might need.
Where can I find Lexmark pinnacle pro 900 driver update?
If you have a Lexmark Pinnacle Pro900 printer and your current driver no longer works after upgrading your Mac to OS X 10.8 Mountain Lion, there are two ways to download the driver. First option is to install the driver by updating your operating system. This method may require that the previous driver be installed. Click on the Apple menu and select “Software Update.”
Lexmark Pinnacle Pro901
On the next screen, see all the available updates for your operating system and install them. See if your Lexmark printer is included in the list of updates. In case the printer is not included on the list, the next option is to download the driver manually from the Lexmark website. Head down to Lexmark Pinnacle Pro901 and select your operating system from the list.
If you are using OS X 10.8 Mountain Lion, under “Drivers & Software” section, select “Macintosh” on the first dropdown list (Operating System) then select “Mac OS X 10.8” on the next dropdown list (Please Select Version). After this, download the driver and install it on your computer. This should fix the problem.
1....
