Where can I find list of NIIT courses among degree programs?
Does anyone know where I can find the list of NIIT courses among degree programs?  I'm hoping to be a Sun Certified Java Programmer (SCJP) and Sun Certified Business Component Developer (SCBCD).  I can't find any list on their website.  By the way, I'm here in India.  Thanks.
Answered By 0 points N/A #170310
Hello William,
                       NIIT has a practice of revealing data about its courses only after they get to know you. So if you plan to know everything from them then fill up the form on the right side in their website and they will contact you within a day.
Currently as far as my knowledge is concerned NIIT offers 3 certification courses on JAVA.
  • Certificate Program in Core Java.
  • Certificate Program in Advanced Java
  • Certificate Program in Core and Advanced Java.
It is upto you now to decide which of the above 3 choices would help you in becoming a Sun Certified Programmer.
Also,NIIT has many branches in many cities spread across India.Hence before joining i would suggest you to do a local enquiry as to which branch would be the best in terms of faculty and support.
Cheers, hope you have a good time in India.
