Hello. I just installed Flash Slideshow Maker Version 1.3 on my iMac with OSx Snow Leopard. I just uploaded my gallery with audio on the internet. Everything works fine including the audio except the pictures won't slide. Where can I find the settings for Mac software photo flash slideshow?
Where can I find Mac software photo flash slideshow settings?
Hi Dorindagmincey,
               Normally once you put your pictures in the gallery the slideshow would work, if for some reason that it will not work whatever you do you can try other options like downloading a Flash slideshow application. I can suggest you a couple of software that can be embedded on your website as well. You can check on Flash Slideshow is compatible with MAC it can build a gallery of flash photos, and you can have background audio on it as well. It can be used to embed photo audio presentation on your website. Another one is slide show audio where in you can multiple effects plus audio back ground while you show your presentation.
