Where can I find Modem line playback download?
I recently ran Avast Antivirus on my PC with Windows 7 64 bit recently and found a lot of virus and malware. Avast eliminated them but I also lost audio. Where do I find modem line playback download?
Hello dear Trent Davis,
Don’t worry; it’s a simple problem. You can restore your file, which was deleted by Avast antivirus. Sometimes Avast detects malware even though it's not a virus or malware. It will be blocked and your infected file will be moved on to the Virus Chest. If you delete this file, then you will lose your file. Now, take a look how can you recover your lost data from Avast. See the screenshot.
You see an option telling you to restore it back to your system. Click it and then your lost file(s) will be successfully recovered back to where it was before. Thanks.
