I'm a current user of RDM+ on my Windows 7 64 bit desktop to remotely access my other computer in my home network. I recently purchased RDM+ mobile for my 8 GB LTE Motorola Droid RAZR Maxx with Dual-core 1.2 GHz Cortex-A9 CPU and Android Jelly Bean. I can't seem to find my RDM android registration code. Can anyone help?
Where can I find my RDM android registration code?
I'm not sure if the registration code will be visible when in mobile mode since downloading an application using an Android device will require the user to have a Google account. So if you want to re-download the same application using another Android device, you will just need to enter and use your Google account on another device and then download it under the account that you used when you purchase the RDM+.
