Where can I find open port for bloodline champions?
I started playing an arena-based PvP game called Bloodline Champions and I connect to the game via wifi.  Ever since I installed a new D-link Cloud Router 3000 (DIR-855L), the game always lags.  Where can I find open port for bloodline champions so I could set the QoS correctly?
Answered By 10 points N/A #164580
Hello My Dear Friend,
I had also faced this problem. Then I did very hard research about this problem and found one solution. I used smartsniff.
I used TCP 7255 for patcher
I used TCP 7001 for "Cryptic 2 Compressed"
I used TCP 7004 for "Cryptic 2"
I used TCP 7012 for client/server communication
I used TCP 80 that is the general HTTP and it is by default forward port.
There is also some guidance for this issue
You can also use Bloodgate (Login/Community Server)  : 10204
You can use Main Server List : 54545
Use for Game Servers : 50000-50500
Hope this will work for you. Good Luck.
