Hi. I have been using Qvod Version 5 for viewing multimedia videos and streaming content. It recently gave a "Please update driver" message and I can't view any media file anymore. Where can I find the Qvod player English version updated driver? I'm on a Windows Vista 64 bit system.
Where can I find Qvod player English version updated driver?
Hello Dudley,
The latest version for Qvod is 5.6 and you can get at the following links:
Remove the one you have right now on your computer, and then download Qvod 5.6 from one of the links provided above and install it. You shouldn't get the error after that.
Fletcher Hoss
Hi Dudley Achan,
The problem might not be on your Qvod anymore, the problem might on your video card now, please update your video card to view some media files, and also check the bit program of your Qvod software, be sure that you are using a 64bit installer for your 64bit machine, updates for Qvod program will be automatically initiated as soon as you've installed the product.
