Hi guys,
Where can I find smart GPRS setting for Samsung wave 2?
I got this Samsung wave 2 from a friend and was not familiar with bada operating system.
I need some assistance along the settings there are some set up to be configured in GPRS to received and send MMS.
Expecting some help,
Thank you.
Where can I find smart gprs setting for samsung wave 2?
Hi
You want a GPRS setting for your Samsung Wave 2.
There you can maintain your internet connection. You said you got one. Try that again if that works.
Otherwise contact your service provider for the settings because such settings vary from one provider to another.
They shall send you the settings that shall work.
sam boy
To create GPRS Settings on Samsung Wave II.
tap settings.
tap connectivity.
tap network.
tap connections.
tap yes to accept confirmation.
To create new Connection, fill out the information.
set name.
access name.
user id.
password.
proxy address (IP).
tap advanced settings then tap set.
To check if it has been saved :
tap connections.
tap internet.
tap internet profiles and check whether the name you set is saved.
Bada Operating System :
It is marketed as a “blue ocean” system, able to embrace a range of exciting new applications for Samsung’s 3g mobiles with a very reasonable price tag attached. The latest version of Bada, Bada 2.0, includes a plethora of new features, 3D graphics, multipoint-touch, a revamped graphical user interface (GUI) and an expanded repertoire of apps available for download and installation.
