Where can i find stile Windows 8 Tune up?
Dear All
I am using Windows XP. Is there any provision for upgrading my Windows XP to Windows 8 directly (By passing Windows 7)? If it is possible, can you people help me finding stile windows 8 tune up?
Dear All
Windows 8 is the latest Microsoft platform. It is the most usable platform and it’s features are very attractive and easy to use, so everyone really likes it. If your computer’s configuration has 1GB RAM and 20GB of free space in the hard disk, then you can install Windows 8 directly.
On the other hand, updating Windows XP to Windows 8 is very difficult and you may face many problems, so it is better for you to install Windows 8 directly.
