Where can I find trial version of Adobe flex 4 builder download?
I want to build desktop and web applications using Adobe Flex 4 SDK and ActionScript.  Where can I find the free version Adobe Flex 4 builder download?  I want to test the new design-develop workflow with Flash Catalyst first.  Any suggestions?  Thanks.
Best Answer by Guy V Mohr
Answered By 0 points N/A #165964
Hello, It’s a matter of happiness for you that Adobe Flex 4 builder is available on Adobe’s website. They have introduced a free version of Adobe Flex 4 for customers, and you can easily download this 328 MB file free from this http://www.adobe.com/devnet/flex/flex-sdk-download.html link. In fact, you can get some exclusive tutorial from this website also. You can get information how to create new features for flash. After all, I believe this site is fearful for beginners like you. So, don’t waste time. If there is any other problem, knock me!
Answered By 0 points N/A #165965
Hello Hernandez,
To develop web and desktop applications you need to download Adobe Flash Builder from the Adobe official website. It supports Adobe flex combined with action script. you can easily develop any sort of application using Adobe Flash builder. I have used it and developed may web applications with Flash Builder. Very easy to use and results are amazing.
To download the Adobe Flash Builder please visit the Adobe official website
