Donna Davis
20 points
Posted on - 05/25/2013
Hi guys. I just found my old Mercury CC-320 webcam. I have been using it when I was still on Windows XP 64 bit. I tried installing it on my desktop with Windows OS 8 but all I see is a black screen. Where can I find an updated Mercury CC 320 USB driver?
Hi Donna,
The reason that you've seen such issue is that your current driver is not well-matched to your Windows OS 8. You should install the upgraded driver in order for you to proceed your transaction. The good news is that you may download Mercury CyberPix CC-320 Drivers that runs in Windows 8. In order to complete the installation, you should remove the previously installed driver and then install this updated driver.
Hope this helps.
There are many sites that you can download the Mercury CC 320 USB driver for free. The last version is compatible with windows 7, XP or Vista. The most suitable site To download is the Driverguide.com. You start the downloading, click the ''Allow'' Option, then ''install'' and the installation will begin.
