I use Rhinosoft to transfer and manage multiple secured files on the server.Â
I now can't access Rhinosoft because it needs authentication in SolarWinds FTP server update which I cannot find on the Rhinosoft website.Â
I was on a Windows Vista 64 bit platform.Â
Where can I find updated Rhinosoft software.
Hi, Virginia,
I want to believe I will help you in solving of your problem in the best way possible. You really don't need to uninstall the Rhinosoft software because you can just download and install the update. The update of the Rhinosoft software can be found from the website.
Download and install it from the website by following the prompts indicated.
Ensure to update your software regularly for good performance.
Reboot your computer for setting to take place effectively.
This should solve your query.
