Where can I find urdu font for samsung mobile
My local language is Urdu, while I can understand English, its not sufficient. My hand phone is Samsung. Where can I find Urdu font for Samsung mobile ?
You can find urdu font from the net. Urdu fonts are available there. What kind of handset you are using, that’s the main fact. If you use Samsung smart phone then it’s easy for you to type urdu.
Urdu font can be found on this website-
http://www.androidpakistan.com/urdu-keyboard-how-type-urdu-on-android-phones/
Hope, you can find some solution.
Go to http://samsung.mobile.brothersoft.com/samsung-i8510-urdu-language.html.
Look for Urdu 1.54 for Samsung i8510 or the application most compatible with the model of your mobile phone, Click the download button on the right side and download this application. Install this application on your Samsung mobile phone. This will enable you to explore your Samsung mobile phone in your local Urdu language. Many other Software and information about Samsung mobile phones can be seen on this site.
Notifications
