I have a Sony Vaio VGN-N105N with 1.83 GHz Core 2 Duo, 2 GB RAM and Windows OS 7 64 bit. I'm looking for a program for Vaio temperature readout. I want to determine the temperatures of my CPU and HDD. Thanks
Where can I find Vaio temperature readout?
Hi Matthew D Martinez,
It means you are searching for “temperature readout software”. To find this software you should search at the Google. Just go to Google and search for “temperature readout software” then you can get many web links. Go to the suggested link and download from there. You mention that you are using Sony Vio, it is not a problem which brand you are using. For your help I am giving you a link where you can download. Depend on ranking I am suggesting you “HDD Temperature Pro”.
Download link- http://hdd-temperature-pro.software.informer.com/
Thank you
