Where can I get an antivirus memory stick?
Is there an antivirus memory stick?
I wonder if there is antivirus that is intended for USB memory stick.
Is it possible to have it installed inside it?
If so, where can I get it?
Dear,
The AVG rescue CD is powerful must have toolkit for the rescue and repair of infected machines. This rescue cd is a equipped with avg antivirus. It provides essentials utilities for system administrators and other IT professionals.
Obviously, it wont create a wonderful impression if I infect the work system with the same virus.
So I planned to stick the memory stick in my system first and use that I have on here to disinfect it, if there's anything on it.
According to my knowledge there is a Guard called "USB security Guard" this is good to detect virus in USB stick.
This software should install to your pc and when you connect the USB its automatically appear and if there is virus in your USB stick it shows, it from there you can delete it. its safe if your pc protect by another Antivirus software also.
You can download USB security software by this link.
Suppose it didn't work give me a message I'll send the link.
Regards.
