Hi. I just recently formatted my desktop that has an AMD Sempron processor, 2 GB RAM, 500 GB HDD, 1 GB Video Card. I could not find my BitDefender Antivirus 2012 ISO DVD. Where can I get the software? Thanks in advance.
Where can I get Bitdefender antivirus 2012 iso?
If you lost the setup DVD of your Bitdefender antivirus, you can always download it from its website. But before downloading it or installing it, make sure your computer meets the requirements. The latest Bitdefender antivirus at the moment supports Windows 7 Service Pack 1, Windows 8.x, and Windows 10. Windows XP and Windows Vista are not supported.
It requires 2 GHz Intel Core Duo or faster processor, 1.5 GB RAM, and 800 MB free space. If you think you have a compatible system, download the latest Bitdefender Antivirus.
