Where can I get the compiler of vb6 convert ios?
20 points
Posted on - 09/19/2012
Is there any compiler available to cover vb6 into ios? If yes, Where can I get the compiler of vb6 convert ios? If not, should I make the compiler myself to use the app of ios in iphone?
Thank You
