My desktop that has a Core Duo processor, 2 GB RAM, 1 TB HDD and Windows 7 has been very slow lately. I did a system check and got error messages of corrupted and missing drivers. Where can I find driver finder to fix my errors? Thanks in advance.
Where can I get driver finder for my Windows 7 system?
Dear Sophieissabell,
You are really talking about an important issue. You may like it as a solution of your problem.
Hello Sophieissabell,
You have mentioned that you are using windows 7 which has been not working properly due to corrupted and missing drivers .Now for fixing this kind of driver error you can download and then install Fixio Driver Finder which can be very useful for these following aspects:
1. Easy to install and configure
2. Can perform advanced diagnostics of drivers and OS
3. Indicate which driver is corrupted or outdated
4. Replace or repair those drivers
I hope to use this application you can fix all of your problems for drivers.
