Where can I get a free Bin loader Mac?
Where can I get a Bin loader mac? My internet is slow, I am connected via broadband so a small file would be nice… Please leave a comment with a direct link if you know of one! Thanks!
Good day Walter,
Here is my suggestion for you to check if you are really having a bad connection.
First of all, there are many reasons if your internet connection is slow.
You might want to check your computer or internet connection why is it slow. But here is the link you're asking for. http://download.cnet.com/Loader/3000-13631_4-206525.html
Hope it help. Thank you and God bless.
The main reason of slow connection of temp files. First of all clear all temp files from system.
Use this procedure for clearing temp file:
1.     Press Windows button + R
2.     Appear new box below. Write %temp% inside the box and hit enter.
3.     New window open, press ctrl+A for selecting all files and delete all files.
4.     Close all windows and restart your system.
If your problem still then try this loader. Please use this below mentioned link for downloading loader (Size: 11.2 MB):
https://www.macupdate.com/app/mac/29153/loader
I wish this solution may be helpful. Thanks!
Best,              Â
Fenster Maxine
