Please give some tips on how to get free PlayStation avatars.
I want to change my avatar at least once a week.
My friend said there is a site where you can get free avatars and themes.
Please recommend free and safe sites.
krish123
Where can I get free playstation avatars?
According to your question, you can easily solve it by following below instructions.
1. Firstly select 'Playstation Network' from the home screen when you first turn on your PlayStation.
2. After that choose the 'Account Management' option and then click ' Edit Online profile'
3. Then you select a new avatar from the option on the screen.
4. After that use the arrows on each side of the avatar to scroll through all of the possible options.
5. When you have decided on an avatar, select it & then select 'Continue' to complete the change.
Hope you enjoy this way to get PlayStation avatars as you wish.
Its look like you have a craze for games and you need to get action on it.
I am sending you a link here that will show you the results for the play station avatars and i hope you will be able to find your desired avatar from there.
Please see the link
Smith Thompson
