Hallo there!
I am new to web design and I would like to get an html tag editor free online for my learning purposes. I have notepad but it does not seem to be user friendly, especially for a new person like me. If the free application could have code auto suggestion then that will be an added advantage. Thanks.
Where can I get HTML editor free online?
Hi Alex,
Hi There man that's a great you are learning Web designing, So you need a editor right it will make your task quite easy.
Well here is one application or editor as you refer it its called HTML KIT though the latest version is to be purchased but the earlier version is available for free,
Hope it will work for you.
Regards Ian M Tyner
Dear Alex A Gonzales,
Welcome you to Web Designing/Developing world. Yes, for being a good web Developer/Designer-
HTML, CSS, PHP, jquery, JavaScript etc are the languages you have to learn well and practice well. So, practice is needed for you badly with the suggestions on the editor what will be very helpful for a beginner like you for better learning.
I will suggesting you to use ''Notepad++'' or ''Macromedia Dreamwaver''  – the editors with suggestions you required.
On online you can learn from w3schools and use their practicing tool.​
Therefore, Download now Notepad++ or Macromedia Dreamwaver and start practicing your coding.Â
Happy coding and best of luck.
