Where can I get a jquery mobile weather using gps?
I want to acquire a phone with jQuery mobile weather using GPS already installed since this vacation I will be hiking with my family. I need to be in check of whether.
Do you have any suggestions?
Answered By 0 points N/A #163789
The best phone that I know has 100% compatibility with the jQuery mobile weather using the Global Positioning System (GPS) is the BlackBerry 10 phone.
Most web application developers are familiar with jQuery’s handset framework that supports Git Hub which enables to have your own web application without much restrictions. You can use geo-location application in this case to acquire weather data.
BlackBerry smartphones enable downloading of certified mobile applications from authorized BlackBerry app developers.
This application can be downloaded from the BlackBerry applications page and install into you system.
Here is its link,
http://us.blackberry.com/apps/blackberry-world/download.html
Hope that helps.
