Young Hern
10 points
Posted on - 07/17/2013
Hello Dear Friends,
I am using IsoBuster 2 1, which is very helpful tool that recovers files & data from the damaged DVD / CD. Please guide me to find the latest version of IsoBuster or suggest me a better alternative or a better software.
Thanks and Regards, Young Hern
Where can i get the Latest version of IsoBuster
Hello Young Hern
IsoBuster 2.1 is an older version of the software, that probably does not fulfill your requirements anymore. In order for you to change this, you can download the latest version, IsoBuster 3.2. I will offer you the link, that also has its release notes. So you will know what has changed, what is new and how will this program help you in the future recovery. This is the link for IsoBuster 3.2 and you have the Download link in the left.
As for similar softwares, that could help you in data recovery, I recommend Power Data Recovery. It is a very good and easy-to-use software. And it will for sure help you with all the data recovery. This is the link for Download .
I hope you will find this information helpful.
Randolph
