Where can I get Linksys Cisco 320 download?
Hallo Guys!
I am having a Cisco 320 and I am having issues with the drivers after formatting my computer. Every time I try to run it, it says that the version of the software is not compatible with my version of Windows. I have tried to carry out Linksys Cisco 320 download but to no avail. What is this with compatibility issue which I never experienced before? Just to mention, I am using Windows 7 Ultimate same as what I was using before.
Best Answer by Darrel R Gonzale
Answered By 0 points N/A #139480
There are many types of Cisco device models that are used in the network today. I just check the internet to find the device you are asking about but there are many such models I can see on the network. The good thing here is I can tell you the way you can solve your problem. Just type 192.168.1.1 in your browser window and your login page for the device will be in front of you, now enter admin as user and admin as password to login to your device now you can set your device as your requirements.
In case your device uses some software then you need to first check the full model of your device like WRT32N and then get the user manual form the website and by using the user manual you can configure your device properly.
Darrel R Gonzale
Answered By 0 points N/A #139481
Hello, Hazelwlee!
It was your Linksys Cisco Router and Gateway WRT320N driver that gives you worries right? So, here’s a twist: according to my reliable source, the driver has a driver conflict, improves computer stability and restores all communication on Wireless router and gateway networks. In this link (which I really trust the most), WRT320N drivers are a high priority update recommended for all Linksys costumers: http://xpdrivers.com/network/linksys/wireless-router-gateway/wrt320n/_5_7905.cfm
Answered By 590495 points N/A #326548
If you need a driver for your Linksys router, try visiting WRT320N Downloads. You need to check the hardware version of your device. You can find it beside or beneath the model number and is labeled as “version”, “ver.”, or “V.” If you can’t find a version number beside the model number, it means the device is version 1.
This Linksys router driver is available for Windows XP, Windows Vista, and Macintosh. You need to unpack the ZIP file after downloading it. You can use WinZip, WinRAR, or 7-Zip to unpack or extract the file. After this, you need to load the file to your Linksys router to update the firmware.
For the complete instructions on how to update the firmware of a Linksys Wi-Fi router, go to Manually upgrading your Linksys Wi-Fi Router’s firmware.
