Hallo there!
Just to feel the experience, I decided to run Linux Mint live DVD and as a matter of fact, I loved it. However, I was not able to figure out Linux Mint CD burning provision. Is it possible to burn a CD or DVD on Linux Mint while running it live? Thanks in advance for your assistance.
Where can I get Linux Mint CD burning option?
You can't burn CDs or DVDs while you are on Live mode. But if you install Linux Mint onto your computer, then you can install the K3B burning tool. To install K3B, open Terminal and type “sudo apt-get install k3b”, then input your password and press ENTER. Now K3B will be downloaded and installed automatically. Now you can burn CDs and DVDs with no problem. Regards.
