Where can I get a Mac wma editor?
I am running Mac OS X, then I have a file with a WMA audio file format. I would like to convert and edit using my computer. Can you give me a good Mac WMA editor? It would be nice if you could give a link where to download it. Thanks a lot expert.
Best Answer by Roth Bridgette
Answered By 10 points N/A #159727
Hi Bob fleming
You want a audio file converter? To MP3?
Here are some steps on how to convert the Audio files to MP3
First step you must download the application of SWITCH  app. Then once your done downloading this image will pop up
so proceed to the next step add files  you want to convert to mp3 just click add files when you have a music library or you have music saved. If the case is specify to the audio output click Browse folder the pick output directory then after select files click CONVERT.
This link is for Switch convertor http://www.nch.com.au/switch/
Hopefully it helps.
Answered By 50 points N/A #159728
I use the free version of Flip4Mac. I do have QT Pro however… I just do an export from QuickTime player, so you don't need the paid version of Flip.
