Where can i get MS JAVA plug-in?
I keep getting notices that I need JAVA to see certain webpages including my online banking and some games. Where can I get MS JAVA plug-in?
MS JAVA was not included in XP. It included in SP1, but it is not included in SP1 later. One can download an older version from several sites. I'd recommend you for SUN version. Maybe VM is simply not enable on the PC. So check here. Start IE. Go to Tools. Internet option. Advance tab. Under Microsoft VM, enable JIT compiler for VM and set the security option to default and reboot.
