Hi Guys!
I have been using my webcam for a while without any issues. Since yesterday, I realized that it is not working anymore. Where can I get MSI Web cam VR 300 drivers? If the driver has a particular way of installation, kindly include the notes to aid me. Thanks big time for your assistance.
Drivers for your webcam come with Windows, so there is no need to download them manually. In order to fix your problem you need to unplug your webcam. Then go to the Device manager -> locate your webcam, and delete drivers for it. Then restart your PC. After your PC boots up again, plug in the webcam and follow the on-screen instructions.
I hope I helped. Regards.
Most newly bought systems have supported drivers for the device to run. Try to look first at the driver disk included in your device, as that is the most compatible software for your MSI webcam. Another thing to point out is, if you are using Windows 7, the Windows Update service automatically finds an appropriate driver for your device. Try it out.
