hirt faust
Posted on - 04/21/2013
Hello Server Experts,
I have several servers that I run and I would like to have a multi server monitor software to use in monitoring all of them. The servers are running both Windows and Linux platforms and therefore the application should be able to work with both platforms.
Where can I get multi server monitor software?
Hello Faust,
Try to use network time protocol or NTP this software is a clock synchronization between a computer system up by packing switched, variable latency data networks. This server supports windows xp, vista, windows 7 and many more. It also provides accurate time and time distribution process can be added.
You can download this software at the link below.
https://www.meinbergglobal.com/english/sw/ntp.htm
The image below is a sample of NTP.
