Hello TechGurus!
I have several important archived files of very high capacity that I would like to extract. I find it a bit tedious going through each one of them and extracting it to a preferred location. To solve this, I would like to get a multiple extract freeware that I can use and let it run as I go about my business. Is there a particular software that you could second for this purpose? Please, underline the work free. Thank you very much for your help.
Where can I get a multiple extract freeware for archives?
Hi Halleleilani2,
You can actually go here http://www.extractnow.com/ and download ExtractNow. This software is easy to use and it can solve your problem of multiple file extraction.
It has a simple user interface,
It has multi-language support,
It can search through folders for archives,
And more features given in the website.
WinRAR is a free archive extractor that can also perform batch extraction. All you have to do is download it from the official site which is winrar.com. Install it on your PC which should be running the windows operating system. After the installation is complete, go to the directory containing the archived files and select all that you want to extract, right-click and on the context menu select the 'Extract files' option. Select the location you'd like to extract the files and click ok. The extraction process will begin.
