I just purchased a used iPAQ 514 (500 series) that has the TI OMAP 850 chipset, 200 MHz ARM926EJ-S CPU, Microsoft Windows Mobile 6.0 Standard OS and Pocket Office.
I can't use the Pocket Office, it says I need to update Office mobile iPAQ 500 series software. Can someone help?
Where can I get Office mobile iPAQ 500 series software?
Hi Dorindagmincey, cool!Â
Windows phone! But it seems you really need to update your windows 6.0 to a windows 6.5 mobile so that your phone will be compatible for pocket office.
But be careful with the upgrading ok?
However, you must have selected the latest pocket office as for the reason why it is prompting you to upgrade.Â
You might want to consider a lower version of those pocket windows for compatibility purposes.
Enjoy!
