Where can I get Orite webcam driver Windows 7
I just purchased a used Orite iCam webcam that has a 640 x 480 fps and 1280 x 960 still image capture.  My Windows 7 desktop could not detect the webcam.  Where can I get an updated Orite webcam driver Windows 7?  Thanks in advance.
Best Answer by
Answered By 0 points N/A #141061
Hello Doriswneil,
You can download it using any of these links. http://downfocus.com/orite/orite+vc3250+driver+windows+7/ ; or https://forums.opensuse.org/showthread.php/390436-orite-rn-3000-webcam-driver.  There are a number of them so you can choose the on which is compatible enough for you to use on your computer
Answered By points N/A #141062
First off, check well your USB connection is right. Then go this site and download your desired one driver for your PC. These software are compatible with almost all Windows. After downloading this driver your Wiondows 7 will be able to detect the Webcam.
Answered By 590495 points N/A #327166
If that is a webcam you installed on your computer, it needs a driver for the machine to identify the camera. If you did not install the driver, there’s no way for the computer to recognize the device. It should be detected when you connect it to the USB port but it can’t be identified.
The driver for the camera should be included in the CD that came with the device. Now, if that camera is already used and the seller didn’t include the installation CD when you purchase it, alternatively, you can use ManyCam instead. It works on any webcam as long as your operating system is supported.
It supports Windows 7, Windows 8.1, and Windows 10 and requires Intel Core i3 or faster processor, 2 GB RAM, and internet connection for subscription activation.
