I want to play quake 3 with my friends through wireless. My pc is 64bit windows 7 and the wireless driver is appropriately install. But I can not configure quake 3 in the windows 7. Where can I get quake 3 windows 7 wireless supported version?
Thank You.
Hey Vivian Drakees,
You can find various versions online, but there are very few forums and websites that suggest Quake 3 for windows 7 64-bit. The manufactures have not officially confirmed about the game to support windows 7 64-bit. If you like to give it a try then surely try running the game through compatibility mode in windows 7 64-bit. Otherwise, you may look at the free version of Quake Live which works perfectly on 64-bit. It is available at http://www.quakelive.com/
The game looks more like Quake 3 and this would work in windows 7 64-bit. If you find any problems or find any ways to run Quake 3 in windows 7.
