I just bought a brand new Samsung Galaxy S I9000 with 1 GHz Cortex-A8 CPU and Android OS, v2.1 (Eclair).
It came without a user manual.Â
Where can I download Samsung Galaxy S user manual PDF format?Â
Thanks in advance.
Where can I get Samsung Galaxy s user manual PDF?
Wassup Jackie, I believe I will be able to help you in the best way possible.
You really don't need to go far or seek far if you want the manual for the Samsung I9000 galaxy S, simply go to the gsmarena website by typing this address; www.gsmarena.com and seeking for the phone in the search tab on the top right corner of the website and hitting enter.
Or simply navigate to the address;
On the left panel under the picture of the phone, you will find various links and on the last link almost at the bottom is the manual. You can download it by simply clicking on it and saving it to your computer. It will come in PDF format which may be viewed in different languages.
I hope this solves your query.
