Where can I get service hp nokia 8800?
I was amazed by this software and now I am wondering where to get the service HP Nokia 8800 and other software associated with this.
Hello Miss. Hall,
You should be amazed by this software because of its amazing features. But how long you would be amazed? Let's start experiencing it now. Just follow the link below…
http://ptf.com/service/service+hp+nokia+8800/
You will get your desired "HP Nokia 8800" application in front of you. Just take a click on start download tab. Then it all will be yours.
Enjoy yourself.
You are looking for service HP Nokia 8800 Application. The best feature of service hp Nokia 8800; you can sync internet facility through the WiFi. Really HP Nokia 8800 has the amazing features.
You can download “service HP Nokia 8800” from the below mentioned link.
http://www.mobileheart.com/cell-phone-softwares/82-Nokia-8800-Software.aspx
I hope it may be helpful.
If you have a Nokia phone and you want a program that will allow you to access your phone from your computer, what you need is Nokia PC Suite. Try downloading Nokia PC Suite 7.1.180.94 on FileHippo. To access your phone from your computer, you need to connect your phone to your computer using the USB cable that came with it.
Once your phone is connected, just start Nokia PC Suite and you will be able to transfer app and music between your computer and your phone. The Nokia 8800 is a discontinued 2G phone operating on 2G network band using GSM technology. It was announced to the public on the first quarter of 2005 measuring 107 x 45 x 15 millimeters and weighing 134 grams.
It uses mini-SIM card. It has TFT display with 256K colors at 208 x 208 pixels screen resolution. It is protected with scratch-resistant glass with downloadable wallpapers and screensavers. It doesn’t support memory card and has 64 MB internal storage. The primary camera supports SVGA and can record video in QCIF. There is no secondary camera. It doesn’t have 3.5-millimeter jack, Wi-Fi, GPS, and USB.
It has Bluetooth 1.2 with A2DP and FM radio. It doesn’t have any built-in sensors. The pre-installed web browser supports WAP 2.0/xHTML. Java is supported via MIDP 2.0. It runs on removable BL-5X Li-Ion 600 mAh battery with standby time up to 190 hours and talk time up to 3 hours. It is available in silver and black edition (for the Russian market) colors.
