Where can I get SQL anywhere 12 ODBC driver?
Hallo there!
I would like to build a database that I can easily use with any programming language. I would like to get this done on ODBC. Does anyone there have an idea where I can get SQL anywhere 12 ODBC driver? Kindly include a little note on how to have it up and running. Thanks in advance for your generosity.
Answered By 40 points N/A #170608
ODBC is basically a connector to your Sql server.  To install it go to this site: https://dev.mysql.com/downloads/connector/odbc/.
Then you need to select your operating system, and find the appropriate version of ODBC and click on the “Download” button.  After the download is complete, you need to run the downloaded file and follow the on-screen instructions.  After installation is complete, you are ready to use Sql.  I hope I helped.
Regards.
